Activity Forums DaVinci Resolve Can’t find batch unlink for ISO? Da Vinci 9
  • Can’t find batch unlink for ISO? Da Vinci 9
    Posted by Brenna Perez on November 26, 2012 at 4:10 pm
    Hey guys,
    I’ve just started using Da Vinci (yesterday), so I’m flying blind here, please bear with me…
    Working with R3D files, I need to make small ISO changes.
    I found elsewhere on the forum that to unlink 2 clips from the same source file to give them different grades, you have to right click and “Batch Unlink” … I can’t find the option anywhere.
    I deleted the automatic group, but I need to apply different ISOs to the 2 clips, is this possible? Under the camera options, I can put the source for ISO as “Clip”, so it makes sense that it batch adjusts, but I’m wondering if anyone knows a workaround?
    Thank you!
    Brenna Perez replied 13 years, 10 months ago 3 Members · 3 Replies
  • Dwaine Maggart
    November 26, 2012 at 5:09 pm
    In V9, Batch Unlink is now called “Use Local Grades”. You can find this menu item by right clicking a thumbnail image on the Color page timeline. This only works for a conformed timeline, and will not work on the Master timeline.
    Dwaine Maggart
    Blackmagic Design DaVinci Support
  • Paul Provost
    November 27, 2012 at 3:45 pm
    But in case you want to retain this behaviour for other clips in you sequence you can create new local or remote “versions”
    http://www.4Kfinish.com | owner-colorist | Hollywood, CA
    http://www.facebook.com/4kFinish
  • Brenna Perez
    November 29, 2012 at 12:57 pm
    Thanks, yeah I’ve been able to use local versions, and multiple remote versions, but it still seems that the ISO choice is locked.
    It makes sense, since we can choose Project, Camera, or Clip (if I recall correctly) to define each clip’s ISO, and it seems that under these options, “Clip” refers to the whole source file. I can adjust the ISO under the “Clip” option fine, but I need it to not apply to all the cuts in the film from the same original source.
    I’m just wondering if there’s any workaround for this specifically.
    Thanks!!
