Activity Forums Apple Final Cut Pro Legacy Can’t find an answer to this: HDV returned from DaVinci as progressive…
  • Can’t find an answer to this: HDV returned from DaVinci as progressive…
    Posted by Seth Thy on April 12, 2012 at 9:29 am
    I can’t find solution for this…
    HDV 1080i50 / 1440×1080 / upper field edited in FCP, sent to DaVinci, returned as Apple ProRes HQ 1980 x 1080 / none field.
    Picture in both projects looks ok on broadcast monitor.
    That was all done before me.
    The problem started when I tried to make mpeg2 / progressive for Digital TV. I tried sent it directly from FCP to Compressor and also tried to make reference file and import to Compressor – and result is the same: huuuge fields problem! First on my computer monitor, which surprised me since file should have been progressive. And than I imported mpeg2 file in FCP and same result was on broadcast monitor.
    Same thing happened when I tried to make PAL DVD – Compressor / DVD Best Quality 90 minutes, authored in DVD SP.
    I don’t know what am I doing wrong…
    Seth Thy replied 14 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
