Activity Forums Adobe Photoshop can’t fade to transparency
  • can’t fade to transparency
    Posted by Martin Pitchard on June 25, 2013 at 11:37 pm
    Pretty new to Photoshop – using CS6 – and can’t solve what must be a pretty basic opearion.
    I want to fade images to trasparency from left to right, right to left, etc.
    I’ve followed tutorials using the gradient tool but it always fades to a black or white background – I want a transparent background.
    Here are some screenshots of my workspace:
    Martin Pitchard replied 13 years, 2 months ago 2 Members · 3 Replies
  • Martin Pitchard
    June 27, 2013 at 7:42 am
    Anyone…?
  • Darby Edelen
    July 10, 2013 at 2:10 pm
    What you’ve done in the image you posted is blended a white gradient with transparency into your image. If you look at the layer thumbnail in your layers panel you may notice that the one on the left (the color data for the layer) now has a white gradient overlaid on it while the thumbnail to the right (the mask for the layer) is still all white.
    What you’ll want to do is select the layer mask thumbnail and then use the gradient tool with a black to white gradient (no transparency). Your image will become transparent where the gradient is black and remain opaque where it is white.
    Darby Edelen
  • Martin Pitchard
    July 10, 2013 at 11:20 pm
    That worked!
    Thanks Darby.
