Activity Forums Apple Final Cut Pro Legacy Can’t export to compressor
  • Can’t export to compressor
    Posted by Chad2754 on September 28, 2006 at 2:47 pm
    I’m using FCP5 on a Macbook Pro. I am not given the option to use compressor-it’s greyed out. My partner use FCP5 on his G5 and has no problem. We have checked the setings and they are the same on both systems. Any suggestions? Thanks
    Rafael Amador replied 20 years ago 3 Members · 2 Replies
  • Jerry Hofmann
    September 28, 2006 at 4:01 pm
    Try reinstalling it after you uninstall it using https://appzapper.com/ to uninstall.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Rafael Amador
    September 29, 2006 at 2:44 am
    Just make sure that you got the sequence to export selected in the Brownser (dark gray). Then you will see the option to export to Compressor highlighted.
    Salud,
    Rafael
