Activity Forums Adobe After Effects Can’t export H264 because of tmpAEtoAMEProject
  • Can’t export H264 because of tmpAEtoAMEProject
    Posted by Amaury Tapawl on February 9, 2015 at 3:25 pm
    I’m having difficulties exporting H264 with Media Encoder.
    I noticed AE created a “tmpAEtoAMEproject” folder, it’s the first time I see this stuff… What is it?
    Media Encoder can’t seem to export my .aep (it’s taking forever), I guess it’s because of this file. Never had a problem like this before it appeared.
    Looks a lot for your time and help
    Matthew Wood replied 11 years, 6 months ago 2 Members · 2 Replies
  • Matthew Wood
    February 9, 2015 at 11:55 pm
    This is the output folder for the file from Encoder, I think… (i have several .aep files with the same tmpAEtoAMEProject…. Well, how about some specifics? What is the folder path? Is that the same output path you used last time with encoder? IF you cancel the output and delete the folder, does it reapppear and if so, exactly at what point. Can you open the folder, is there anything inside?. and such
    Do you have sufficient cache and memory? Maybe clear them…. —edit.. maybe clear through AE and then if files still remain, delete through windows. It must have something to do with cache…
    And, but, also, you have other ways to get it to encoder, just saying. You are not “stuck”, can output other formats or through AE and then load into encoder
    Blood type O negative. I bleed zeros and ones
    I dabble on the desktop
    Shifted Leering, Any Perspective
    Shifting Literally All Perceptions
    SLAP
  • Matthew Wood
    February 10, 2015 at 12:13 am
    And, so, google is your best friend, ya know? Try rendering to a different folder path, apparently that will solve
    SLAP
