Activity Forums Sony Cameras Can’t export from FCP to PDW-F330
  • Can’t export from FCP to PDW-F330
    Posted by Lucas Young on June 26, 2008 at 6:24 am
    Hi
    I have a sequence that came from an XDCam EX that I’ve cut in FCP 6.0.3 and want to export to XDCam disk. I’ve got a PDW-F330 hooked up via Firewire, with a newly erased disk in it, and it’s set to:
    System: 50i (I’m in New Zealand)
    Rec Format: MPEG HD
    Bit rate (HD): HQ
    Audio CH (HD): 2ch
    Country PAL AREA
    My footage and Sequence Presets are XDCam EX 1080i50 VBR 35MB/s
    I’m using the latest XDCam Transfer Software. But whenever I export to XDCam, whatever preset I choose doesnt matter, I get a warning :
    Export failed
    Please check that your XDCAM device is setup correctly and that the REC INHIBIT indicator is off.
    The device should be configured like this:
    Video: MPEG HD 50i. Audio: 2 ch x 16 bit
    Error writing MXF file
    I exported the whole project to 1080i50 XDCAM HD VBR, created a new project with this setting, and the same problem occurs.
    Can anyone suggest something else I could try?
    cheers in advance
    Robert Dexter replied 18 years, 2 months ago 2 Members · 2 Replies
  • Lucas Young
    June 26, 2008 at 7:48 am
    Further investigation reveals I can export the .MXF file to my drive OK, but even if I shoot a clip on the camera, import it and try and export it right back out again I get the same error….
  • Robert Dexter
    June 27, 2008 at 8:45 am
    If you’ve exported an MXF file successfully to your hard disk drive, you can try using Finder to copy it into the Clip folder of your Professional Disc in your PDW-F330… but if the straight-to-disc export failed, using Finder isn’t likely to succeed either honestly.
    There are so many things to get right on the camcorder to make sure export works, but it sounds like you’ve ruled out most of them! If you’ve tried exporting back a short clip you’ve just recorded on the PDW-F330 itself, that just leaves:
    not enough disc space – the ‘free space’ can be misleading so try a blank disc,
    an MXF file name that XDCAM doesn’t like – check whether the camcorder’s in ‘free’ naming mode or not and choose an appropriate name; the simplest check with the blank disc is to rename your file on hard disk to “C0001.MXF” before copying it with Finder and see if that works
