Can’t edit video portion of Divx file
Posted by Michelle Taylor on January 6, 2006 at 4:01 pmI rendered a Divx file in Vegas. When I load the Divx file to edit it, only the audio tracks appear. The file plays fine in several different media players.
Michelle Taylor replied 20 years, 9 months ago 3 Members · 10 Replies -
Edward Troxel
January 6, 2006 at 5:18 pmOk, if you wanted to edit the file – why render to DivX instead of DV-AVI or something less lossy?
DivX is, technically, not supported by Vegas. Many have gotten it to work. Do a search for DivX or XVid and you’ll get lots of hits and suggestions. Bottom line – you don’t have the proper codec installed for Vegas to see the video.
Michelle Taylor
January 6, 2006 at 6:40 pmI did search prior to my initial post and did not find any relevant posts.
I need to edit some divx files from an outside source. I only rendered to divx to see if Vegas could open a file that it had rendered.
I don’t understand why a codec which is sufficient to render a divx file and also for playing in media players is not sufficent for Vegas to see the video. -
Edward Troxel
January 6, 2006 at 7:17 pmBecause there are different codecs that work in different environments. WMP can use some codecs that Vegas can’t see.
Here’s some answers:
https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=24&postid=634503&archive=T
https://www.sonymediasoftware.com/forums/ShowMessage.asp?ForumID=4&MessageID=431421
https://www.sonymediasoftware.com/forums/ShowMessage.asp?ForumID=4&MessageID=401930
https://www.sonymediasoftware.com/forums/ShowMessage.asp?ForumID=4&MessageID=380987
https://www.sonymediasoftware.com/forums/ShowMessage.asp?ForumID=4&MessageID=351900
Michelle Taylor
January 6, 2006 at 8:41 pmThank you for the links. It looks like it would be best to convert the divx files to an avi type that Vegas can handle.
Laszlo Kovacs
January 6, 2006 at 10:37 pmOK, you’re on your way,
I just want to recommend you
virtualdub.
That’s a tiny, fast tool
for getting out video from divx.
And it’s free. -
Michelle Taylor
January 6, 2006 at 11:09 pmI have vdub. I tried using it for this but it was going to take hours to do just one 30 minute video. I set both audio and video for Full Processing Mode. I tried a variety of codecs.
Laszlo Kovacs
January 7, 2006 at 12:24 amDivx is fast to decode,
you should choose a codec
wich is faster to encode.
Try Morgan Multimedia MJPEG,
it’s horribly fast, and very good
quality at encode and decode.
It is free for 60 days.
Vdub and vegas works fine
with it. -
Michelle Taylor
January 7, 2006 at 12:51 amSince the files have already been heavily compressed once and will be heavily compressed again when I render from Vegas, I’m wondering if it’s good to convert to a heavily compressed format to prepare for editing.
Laszlo Kovacs
January 7, 2006 at 9:14 pmSo, do you want to edit it?
>different media players.I thought you want to edit an already rendered file, let’s say
because you lost the source footage.
If yes, go on.At least I myself didn’t find another way to alter a divx
file, just recode it to anything Vegas can eat.
Mjpeg or huffyuv avi is one of the choices, and are not so highly
compressed as divx. You can figure out
other solutions as well.20 minutes of 720*576 25 fps (MJPEG) video (PAL) is a bit more then
2.3 GB. Is this highly compressed? ;))By(t)e
Laca -
Michelle Taylor
January 7, 2006 at 9:40 pmI guess MJPEG isn’t as lossy as I thought. Thanks for the suggestion.
