Activity Forums Blackmagic Design Can’t edit to tape to Pan AJ-D95dc
  • Can’t edit to tape to Pan AJ-D95dc
    Posted by Don Fito on July 1, 2005 at 5:11 pm
    I can’t edit to tape from FCP 5 to a Panasonic DVCPro AJ-D95dc deck. Both “Insert” and “Assemble” are grayed out when I drag a sequence to the Edit to Tape window.
    The deck has Analog Y and SDI video conectors. I have tried both independently with the same result. I can print to tape. I can also black and code from the Edit to Tape window. The deck is set to remote and I have selected the correct position for the “Input Select” switch on the front, analog for Y and SDI for SDI. “Rec Inhibit” is turned off.
    Configuration:
    Dual 2.7 G5 4.5 GB RAM, fibre channel
    2.8 TB XServe RAID
    Decklink Extreme
    Dual 23″ LCD monitors
    OSX 10.4.1
    QuickTime 7.0.1
    Shane Chadder replied 21 years, 2 months ago 2 Members · 2 Replies
  • Shane Chadder
    July 2, 2005 at 9:56 pm
    I’m pretty sure that isn’t an edit capable deck. Check Panasonic.com.
  • Shane Chadder
    July 2, 2005 at 10:02 pm
    Now I’m confused. I can’t find that deck on the Panasonic site. I thought you meant the AJ-SD93 which has the following footnote…
    “Footnotes
    1 The AJ-SD93 will record the output from a nonlinear editor. Adding optional accessories will not enable insert editing capability.”
    You have to go up to a AJ-SD930 to get insert editing in Pro50.
