Activity Forums Maxon Cinema 4D Can’t Edit text in Cinema 4d
  • Can’t Edit text in Cinema 4d
    Posted by Shane8 on April 23, 2007 at 12:21 am
    I’m using cinema 4d version 9.6 for mac. I was changing text and some how I managed to turn off the ability to edit the text. I can change font, align, height, horizontal spacing, ect…all but the text. Any Ideas how to get that option back
    Shane8 replied 19 years, 4 months ago 2 Members · 2 Replies
  • Arndt Von koenigsmarck
    April 24, 2007 at 7:35 am
    Do you still have the original Text spline primitiv object or did you convert it to a spline object?
    If you converted it (pressing c could have caused this) you can only get back to your original text spline by using undos or adding a new text spline and entering the text there again.
    Kind regards,
    Arndt von Koenigsmarck
    https://www.vreel-3d.de
    https://www.vonkoenigsmarck.de
  • Shane8
    April 24, 2007 at 4:51 pm
    Thanks for replying. This is what i did. In the Object Properties box I right clicked on the text box right next to the key frame, (not the text box where you type your text. A menu came up. in that sub menu are options for animation, user interface, copy, select all, deselect all… I clicked on User interface. In that submenu I had three options, String, Multi line string and Static Text. I just wanted to see what each of them did. When I clicked on Static text I lost the ablilty to edit my text. Do you know how to undo this?
