Activity › Forums › VEGAS Pro › Can’t edit text & can’t play with the effects –>Sony Vegas Pro 12.
  • Can’t edit text & can’t play with the effects –>Sony Vegas Pro 12.
    Posted by Shnepsey Gorlando on June 20, 2013 at 11:05 pm
    Hello everyone, so I tried to use google and this forums to search an answer to my question..
    I’ve been trying to fix it out for like two weeks now, couldn’t find any way..so I just gave up and here we go.. I’m making a topic :).
    And for your information, I formatted my computer about 2months ago.
    I had sony vegas pro 12 before and everything worked fine..those problems came up only after I formatted my computer.. and I formatted my computer like I did in other times..just the same.
    And this error came up so.. I’m kind frustrated here..
    Well, so the first problem is :
    When I add a text by clicking on :
    1)Insert
    2)Text Media
    The window where I suppose to type what I want in the text pops up, but I can’t change the text.
    Here you go for screenshot : https://oi39.tinypic.com/28mioax.jpg
    The second problem is :
    When I add some effect to my video, I can’t play with the settings of the effect I added, usually the effect comes up fine but I can not change the settings of the effect.
    For example, blur effect.. I can’t change the settings of the blur..
    Here you go for screenshot : https://oi44.tinypic.com/r7k4td.jpg
    Anyways buddies! I’ll be thanksfull for any help about that issue.
    Thanks in advance,
    -Shnepsey.
    Raquel Cordeiro replied 13 years, 3 months ago 3 Members · 3 Replies
  • Graham Bernard
    June 21, 2013 at 6:13 am
    What build of Vegas are you running? You could try Ctlr+Shift on firing up Vegas to reset to Factory default.
    Is it possible that formatting the disc has required you to register your copy of Vegas? Maybe you’ve used up your Serials?
    Could be that formatting and the subsequent Restore has broken some necessary linkages to the various elements of running the Vegas, and there that would be the Registry for the Fx-ing and Text modules. Other than a full removal of Vegas and then a reinstall I’m out of ideas.
    Keep us posted – yeah?
    Grazie
  • Shnepsey Gorlando
    June 21, 2013 at 2:11 pm
    “What build of Vegas are you running? You could try Ctlr+Shift on firing up Vegas to reset to Factory default.”
    Build?I’m pretty sure its 563 if that’s what you mean.
    ” Is it possible that formatting the disc has required you to register your copy of Vegas? Maybe you’ve used up your Serials?”
    No it didn’t and I tried to re-install once and try to run the trial version..and same problem came up.
  • Raquel Cordeiro
    July 1, 2013 at 4:41 pm
    The same is happening to me. Have you find a solution already?
