can’t edit on timeline
Posted by Jim Buttery on February 22, 2014 at 6:39 pmI had some 8mm file converted to prores .mov files. I can’t edit the .mov files or the .wmv that I rendered them as. It seems like I can’t select any sections on the timeline. Any ideas?
Jim Buttery replied 12 years, 7 months ago 5 Members · 13 Replies -
Graham Bernard
February 22, 2014 at 7:32 pmSounds like whatever you have on that TL is being recognised by Vegas.
Can you send it through MediaInfo?
G
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Jim Buttery
February 22, 2014 at 7:42 pmThanks for the reply. Yes, I recently formatted hard drive and will have to download MediaInfo. I’ll be back
Jim Buttery
February 22, 2014 at 7:49 pmThis is from MediaInfo:
General
Complete name : C:\Users\Jim\Videos\Sony\Transfer 1\102.wmv
Format : Windows Media
File size : 141 MiB
Duration : 2mn 54s
Overall bit rate mode : Constant
Overall bit rate : 6 780 Kbps
Maximum Overall bit rate : 6 764 Kbps
Encoded date : UTC 2014-02-22 18:08:46.970
SfOriginalFPS : 239760Video
Format : VC-1
Format profile : MP@HL
Codec ID : WMV3
Codec ID/Info : Windows Media Video 9
Codec ID/Hint : WMV3
Description of the codec : Windows Media Video 9 – Professional
Duration : 2mn 54s
Bit rate mode : Constant
Bit rate : 6 519 Kbps
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 4:3
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.175
Stream size : 135 MiB (96%)
Language : English (US)Audio
Format : WMA
Format version : Version 2
Codec ID : 161
Codec ID/Info : Windows Media Audio
Description of the codec : Windows Media Audio 9.2 – 192 kbps, 48 kHz, stereo (A/V) 1-pass CBR
Duration : 2mn 54s
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 3.99 MiB (3%)
Language : English (US) -
Jim Buttery
February 22, 2014 at 7:52 pmThis is MediaInfo from the original HUGE .mov file:
General
Complete name : C:\Users\Jim\Videos\Sony\Transfer 1\102.mov
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 2.00 GiB
Duration : 2mn 54s
Overall bit rate : 98.8 Mbps
Encoded date : UTC 2014-02-18 21:27:18
Tagged date : UTC 2014-02-19 19:43:16
Writing library : Apple QuickTime 7.7.1
com.apple.proapps.logNote : Untitled 01
com.apple.proapps.reel : 001
com.apple.proapps.scene : Scene 01
com.apple.proapps.shot : 01
com.apple.proapps.angle : 01Video
Format : ProRes
Format version : Version 0
Codec ID : apcn
Duration : 2mn 54s
Source duration : 2mn 54s
Bit rate : 98.8 Mbps
Width : 1 920 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 17.946 fps
Color space : YUV
Chroma subsampling : 4:2:2
Bits/(Pixel*Frame) : 2.655
Stream size : 2.00 GiB (100%)
Source stream size : 2.00 GiB (100%)
Language : English
Encoded date : UTC 2014-02-18 21:23:00
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709Other
Type : Time code
Format : QuickTime TC
Duration : 2mn 54s
Time code of first frame : 00:00:00;00
Time code settings : Striped
Title : time
Language : English
Encoded date : UTC 2014-02-19 19:43:16
Tagged date : UTC 2014-02-19 19:43:16 -
Graham Bernard
February 22, 2014 at 9:08 pmProres isn’t something I’m familiar with. But maybe somebody else here can advise you. Do try the SONY Vegas Forum where I know Prores gets discussed by people who do use it.
Grazie
Jim Buttery
February 22, 2014 at 10:14 pmGraham
Thanks for your time. I’d try Sony tech support, but never get a response.
I’ll wait here to see if someone else can help or maybe repost on Monday. Thanks again.
Jim
Graham Bernard
February 22, 2014 at 10:22 pmJim, I apologise, I’m meaning the Official SONY Creative Software Vegas Pro Forum.
Grazie
Jim Buttery
February 23, 2014 at 5:26 pmVegas Pro 12 using a Dell Inspiron N5010 laptop, 8GB RAM, Intel I5 Quad @ 2.3 GHz, Intel Standard Graphics, no GPU
I am able to apply Video FX to the preview, but can’t select or edit a portion of the file on the timeline.
https://www.dropbox.com/s/i3qnb3rq2tvipcy/102.wmv
Here is the MediaInfo for a sample file:
General
Complete name : E:\Transfer 1\102.wmv
File size : 141 MiB
Duration : 2mn 54s
Format : VC-1
Codec ID : WMV3
Duration : 2mn 54s
Color space : YUV
Bit depth : 8 bits
Format : WMA
Codec ID : 161
Duration : 2mn 54s
Bit rate : 192 Kbps
Bit depth : 16 bits
Norman Black
February 24, 2014 at 12:06 am[Jim Buttery] “I am able to apply Video FX to the preview, but can’t select or edit a portion of the file on the timeline.
https://www.dropbox.com/s/i3qnb3rq2tvipcy/102.wmv“
“can’t select or edit a portion of the file on the timeline”
This is a vague statement. What exactly do you mean by this.
I downloaded the video file. I can put it on the timeline. Vegas said it created an audio proxy file. I can play it. I can position the cursor within the event and the preview window displays as expected. I can trim the ends of the event on the timeline.
It does work in the trimmer window but the behavior is strange there. Only the audio waveform is shown in the window until you play, then the video is shown. When I stop, then the trimmer window goes back to the audio waveform display. This makes trimmer window usage with this clip unusable.
Mark Thompson
February 24, 2014 at 10:53 amHi, I downloaded your clip and it appears to me to be what I would have expected. You overdid the aging effect a bit 🙂
SVP could not find an audio track, instead it created an audio proxy (which has no sound that I could tell). If there is audio there you will have to try some other tool.
The way to edit it is to forget the trimmer and just use the main timeline. Use ‘S’ (split) to separate the joined up clips you have. I put a little text in the middle and again all worked as expected.
