Activity › Forums › VEGAS Pro › cant edit generated media
  • cant edit generated media
    Posted by David Cook on August 19, 2009 at 2:33 am
    Ok well i have sony vegas pro 9 and i cant edit my generated media because i was doing just that and accidentaley moved it to the bottom of my sreen. Now when i try to edit nothing pops up, i assume it is poping up at the bottom where i can not retrive it or see it but i dont know. Its been like this for about a week now and i cant figure out how to fix it PLZ help.
    David Cook replied 17 years, 1 month ago 3 Members · 3 Replies
  • Mike Kujbida
    August 19, 2009 at 3:35 am
    Try setting your Task Bar to auto-hide and see if it shows up at the bottom of your screen.
  • Terry Esslinger
    August 19, 2009 at 4:16 pm
    If Mikes suggestion doesn’t work try resetting the screen resolution to a higher resolution. Right click on your desktop in an empty space and choose properties on the pop up menu. Choose settings and then reset to a hiher setting. This will make everything smaller and you should see the window. Move the window back into the middle of the screen. Then redo the settings to your original.
    If you are already at your highest resolution you are SOL. Just kidding! You might try rebooting Vegas while holding the shift key. That resets everything to factory default and your window will be back in place. BEWARE – you will lose any custom settings you have applied. Also I always forget wheteher it is shift or ctrl or alt but I believe it is shift.
  • David Cook
    August 19, 2009 at 5:26 pm
    thank you soooooooooooooooooooooooo much this has made me sooooo happy i was getting so pissed off with technology thank you guys sooooooooooooooooooo much
