Activity › Forums › Maxon Cinema 4D › Can’t edit editable objects
Posted by Miguel Gonçalves on February 24, 2016 at 9:59 pmafter I convert to editable, I try to edit it but it gets white and can do nothing, in another projects I can do it. I don’t know what i did wrong to this happen.
here is the screenshot:
9820_capturar.jpg.zipAndy Sills replied 10 years, 6 months ago 2 Members · 6 Replies -
Andy Sills
February 25, 2016 at 5:02 pmIt sounds like youre not selecting the correct option here.
On the top left of the screen there should be some boxes for what part of the object to select (ie points, edges, polygons)
Your attached picture is password encoded 🙂 -
Andy Sills
February 25, 2016 at 5:50 pmOh the password.
Yeah, I would just make it editable again, im not an expert but white usually means its highlighted.
I made a cube editable here as well and I can select different things. -
Miguel Gonçalves
February 25, 2016 at 6:30 pmI know how to make it editable, I can do it on other files but not on this one, I dont know what I did to make this happen
Andy Sills
February 26, 2016 at 9:02 pmJust found out man, while you’re on the selection mode, bottom right of your screen, “soft selection mode is on” click off the enable and you should be good to go. 🙂
