Activity Forums Apple Final Cut Pro Legacy Can’t drag clip to canvas
  • Can’t drag clip to canvas
    Posted by Kimberley Hogarth on June 18, 2010 at 11:10 am
    Hi
    I can’t seem to drag the clip from my viewer to the canvas window. When I do the clip just disappears. There’s no recognition of the clip in the canvas window at all – it just disappears (as I darg it) from the viewer.
    Any ideas?
    Kimberley
    Matt Davis replied 16 years, 2 months ago 3 Members · 2 Replies
  • Steve Walker
    June 18, 2010 at 4:40 pm
    Hi Kimberley,
    if you’re dragging from the viewer to the canvas, as you hover the clip over the canvas your editing options should appear ‘insert/overwrite/replace etc etc)
    if your trying to drag the clip from the canvas to the viewer (which is actually trying to re-position the clip way off in the x-y space) then it disappears as you describe,
    Steve Walker – MacBook Pro, 3.06 GHz, 4 GB Intel Core Duo, Lacie sata II express card w/ 2TB Lacie Quadra, MIDI from M-Audio Firewire 410. FCP 7, Logic Pro 9
  • Matt Davis
    July 15, 2010 at 9:30 pm
    If anyone else is dealing with this.
    Make sure your Viewer is set to “Image” and not “Image+Wireframe.”
    If it is the latter it will try and position the selection within the Viewer and therefor not let you drag outside of it.
