Activity Forums Adobe Premiere Pro Can’t create mask on Superwhite
  • Can’t create mask on Superwhite
    Posted by Frederick Fisher on March 29, 2013 at 4:38 pm
    I have a PAL clip where the sky has blown out to white. I would like to add a light tint of blue to the sky but when I use the three way color corrector to add a mask using secondary color correction, the sample area of the clip continues to show black and not the white mask.
    I have tried first to reduce the luma down to 1.0v and then re-do the mask but no difference.
    Why is this happening and what is the work-around?
    Frederick Fisher replied 13 years, 4 months ago 2 Members · 2 Replies
  • Ivan Myles
    April 10, 2013 at 10:42 pm
    Try applying the correction to the clip in a nested sequence, then apply the mask to the sequence.
  • Frederick Fisher
    April 10, 2013 at 11:04 pm
    Hi and thanks for the tip. I’ll check it out.
