Activity Forums Adobe After Effects Expressions can’t convert wiggle espression to keyframes…
  • can’t convert wiggle espression to keyframes…
    Posted by Scott G on March 22, 2006 at 8:07 am
    i have a stock standard wiggle expression [wiggle(5,50)] that i want to convert to keyframes so i can put an ease on the movement.
    when i choose keyframe assistant, convert expressions to keyframes is grayed out.
    can the wiggle expression be converted? why can’t i choose this option?
    frustrated,
    scott.
    Scott G replied 20 years, 6 months ago 2 Members · 2 Replies
  • Mylenium
    March 22, 2006 at 8:22 am
    Have you selected the property you want to convert?
    Mylenium
    [Pour Myl
  • Scott G
    March 22, 2006 at 11:17 pm
    ahhhhh i see. i had the layer selected, didn’t work. selected the expression, didn’t work. heh.
    now, shouldn’t it create a keyframe at extremes of motion, not every single damn frame? there’s no point converting to keyframes and applying an easy ease if every frame of the motion is keyframed. must i delete all the keys i don’t want manually??
