Activity Forums Apple Final Cut Pro Legacy Can’t connect to 3rd monitor
  • Can’t connect to 3rd monitor
    Posted by James Bruehl on April 23, 2008 at 4:57 pm
    I’m at the end of my rope on this issue, I have tried everything I can think of to try – hoping some FCP genius here will make me look bad and solve it like its nothing! Please! Somebody! Make me look bad! 🙂
    I have a Mac Pro setup running dual monitors and FCP6…
    Mac Pro Dual-Core Intel Xeon 2.66 GHz 4GbRAM
    With a BlackMagic Decklink SP card installed…
    https://www.blackmagic-design.com/products/sd/techspecs/
    I’m trying to use the “Analog Video Output” of the card to display a third monitor. The monitor I’m attempting to use is…
    JVC DT-V100CG Multi-Format Monitor
    We get beautiful signal through the same monitor from the camera while shooting, but for some reason I can’t get a signal into it from the Decklink card. OSX shows that a third monitor labeled “Television” exists, but the monitor only continues to flash…
    Out of Sync
    UNDER
    COLOR
    MARKER OFF
    I have tried so many different settings in FCP I can barely even remember what I have tried and what I haven’t. Any suggestions welcome!
    TIA
    Tom Meegan replied 18 years ago 2 Members · 1 Reply
