Activity Forums Apple Final Cut Pro Legacy Can’t Capture with HVR-M15N
  • Can’t Capture with HVR-M15N
    Posted by Isaac Orcino on September 13, 2007 at 11:44 am
    Hello,
    I’m having a problem with a HVR-M15N (Hdv player). I working on a G4 1GHz and when I open Final Cut Pro 5.1.4, it doesn’t connect to the player. But when I open the Log and Capture window I can control de player but can’t get no image. The strange thing is when I use iMovie it connect perfect. Is there anything that I can do to fix this? So that I can use it on FCP.
    Isaac Orcino
    Goiânia,Goiás, Brazil
    +5562 81335462
    Josh Smith replied 19 years ago 3 Members · 12 Replies
  • 12 Replies
  • Walter Biscardi
    September 13, 2007 at 1:28 pm
    We use this deck almost every day with FCP.
    My guess is that you’re trying to capture DV footage but your deck is set up in HDV mode, or vice versa. Also, you need to set up your iLink control to DV if you’re in DV mode and HDV if you’re in HDV mode.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Isaac Orcino
    September 13, 2007 at 7:00 pm
    I’ve Tried everything and it still doesn’t connect. I teste on a G5 and it worked ok. The this is that I can’t get it to connect on the FCP on the G4 machine. Could it be firmware or something?
    Isaac Orcino
    +5562 81335462
  • Josh Smith
    September 16, 2007 at 5:23 pm
    This has happened to me before…trash your fcp preferences and restart the program…hope that helps.
    On another note…have you figured how to caputre HDV downconverted to DV in a letterbox format from that deck?
  • Walter Biscardi
    September 16, 2007 at 6:08 pm
    [nsmagic] “On another note…have you figured how to caputre HDV downconverted to DV in a letterbox format from that deck?”
    That’s in the iLink controls.
  • Josh Smith
    September 16, 2007 at 6:13 pm
    Mine only seems to have the option to squeeze or cut it off..can’t find the letterbox option
  • Walter Biscardi
    September 16, 2007 at 6:21 pm
    I’m not in the shop today, but I know both of our 15’s are set up for letterbox and I’m all but certain it’s in the iLink downconvert setup.
  • Isaac Orcino
    September 17, 2007 at 11:07 am
    Ok… Thank you guys for the tips but i’ved tried everything and nothing worked… for some reason the player is not comunicating with FCP. I even reinstall FCP but no success. The strange thing is that when I use iMovie it works normaly on any mode, HDV or DV. My last option is to format the G4 and reinstall everything. I hope it works. I’ll tell you guys later.
    Thanks for everything!
    Isaac Orcino
    +5562 81335462
  • Josh Smith
    September 17, 2007 at 1:43 pm
    I hate to see you forced to do that…i would be curious if that worked, because it sounds like software not hardware and that would mean either a setting issue or trashing prefs…
    Sorry I couldn’t be more helpful…GL.
  • Josh Smith
    September 17, 2007 at 1:45 pm
    Thanks Walter…I appreciate you checking on this…I’ve looked in teh ILINK controls and don’t see letterbox. I’ve got an HVR-M15U…Maybe that’s only an option in the m15N…let me know if you see it some place I’m missing.
    Thanks Again.
  • Walter Biscardi
    September 17, 2007 at 2:05 pm
    [nsmagic] “‘ve got an HVR-M15U”
    that’s the same machine we have. According to Sony’s specs on the M15 and M25 product line, the iLink features are common to all machines.
