Activity › Forums › VEGAS Pro › Can’t Capture Video In Vegas Pro 11 or 12
  • Can’t Capture Video In Vegas Pro 11 or 12
    Posted by Jim Prisby on October 21, 2012 at 4:57 pm
    I just discovered this problem today and have never had this happen before. When I click on the capture video command in Vegas Pro 11 it opens the capture window but then gives me this error message:
    “The device ‘corelscreencapture’ could not be opened. Please make sure it is turned on and not being used by another application or user.”
    When I click on ‘Video’ at the top of the capture window it lists:
    Corel Camera Plug-in
    Corelscreencapture
    UScreenCapture
    The capture window has the title – Sony Video Capture 6.0 – default*
    In the preferences the external video capture application is set to – C:Program FilesSonyVegas Pro 11.0vidcap60.exe (the back slashes don’t show in this text format).
    I did have Corel Video Studio Pro 5 installed so I uninstalled it and used Ccleaner to remove further references to it. I also installed Vegas Pro 12 trial version but I still get that same error message in both Vegas 11 & 12. When I go directly to the vidcap60.exe file in Vegas 11 & 12 and click on it it gives the same error message. Please help if you can as I am unable to capture a much needed video from a tape in my old Sony Hi8 video camera.
    Intel 2.67GHz Core2 Quad CPU.
    8 GB RAM
    NVIDIA GForce GTX 570 superclocked
    Windows 7 64bit
    John Rofrano replied 13 years, 11 months ago 2 Members · 3 Replies
  • John Rofrano
    October 21, 2012 at 7:33 pm
    [Jim Prisby] “I did have Corel Video Studio Pro 5 installed so I uninstalled it and used Ccleaner to remove further references to it.”
    Apparently not all since your PC still thinks that there is a ‘corelscreencapture’ device installed.
    I assume you are trying to capture to firewire? Does your firewire device show under the Video menu item? This should allow you to select it and then save it as the default. If you are only seeing the three Corel devices then your other problem is that your firewire camera is not being seen.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jim Prisby
    October 22, 2012 at 1:38 am
    Thanks, John. I am using firewire and your words stirred me to check the firewire cable connection to my desktop. It had backed out just enough to lose the connection so I pushed it in and all is well. Just didn’t expect that to be the problem since it’s never backed out before. The simple solutions are always the best ones.
    8 GB RAM
    Windows 7 64bit
  • John Rofrano
    October 22, 2012 at 10:50 am
    Glad you found it. I would still contact Corel and see if they have a way to completely remove their software.
    ~jr
