Activity Forums Apple Final Cut Pro Legacy cant capture PAL
  • cant capture PAL
    Posted by James Mccormick on August 31, 2009 at 4:52 pm
    I just captured from an NTSC digi beta machine through a black magic card into final cut pro, then i unhooked the NTSC digi beta and hooked up a PAL digi beta machine. I changed the easy setup to Black magic PAL 8 bit and made sure my capture settings were also black magic PAL 8 bit, but i still get no audio or video in my log and capture window. does any one have any idea what my problem is?
    Michael Gissing replied 17 years ago 2 Members · 1 Reply
  • Michael Gissing
    August 31, 2009 at 10:23 pm
    Do you have reference video hooked up to the Blackmagic card? Obviously if you change to PAL, both machine and card should have a PAL reference signal.
    I presume you are getting picture and sound playback on the PAL machine straight to a monitor.
