Activity Forums VEGAS Pro Can’t Capture From New Camera
  • Can’t Capture From New Camera
    Posted by Bob Hobart on September 26, 2008 at 8:14 am
    For years I’ve captured video to Vegas (currently use V7) from my old Panasonic NV-MX7 using a firewire DV cable (which I also bought years ago).
    Just got a nice new Canon HV30 HDV but capture just won’t work for me. I’m using the same old firewire cable but Vegas capture screen doesn’t recognise any device connected. If I switch back to my Panasonic, capture works.
    Appreciate any thoughts as to why this might be so. Has firewire technology changed? Do I need upgrade to Canon’s recommended optional DV cable or should I be looking at my camera settings for a solution.
    I appreciate that Vegas Pro 8 is a HD product but I would have thought that Vegas 7 should at least capture HD even if the final product is in SD standard.
    Bob Hobart replied 18 years ago 3 Members · 3 Replies
  • John Rofrano
    September 26, 2008 at 1:45 pm
    There is a new capture utility for HDV in Vegas 7. The DV Vidcap program won’t work (as you have seen). When you go to capture, Vegas should give you a choice of capturing HDV or DV before either capture program starts (actually the HDV one is built-in and will be a dockable window)
    If you don’t get asked to choose, you make have selected DV as the default in the past and asked Vegas to stop asking you. Go to Options | Preferences | Video and uncheck Use external video capture application . This is should return to asking you whether to capture DV or HDV again. Then select HDV to capture from your HDV camera.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Charles Avanti
    September 26, 2008 at 3:29 pm
    Also, check the “Output” options in your camera.
    Charlie
  • Bob Hobart
    September 26, 2008 at 10:51 pm
    Thanks John and Charlie – your suggestions worked. I’m now a happy man.
    Bob
