Activity Forums Apple Final Cut Pro Legacy can’t capture from Canon HV-30
  • can’t capture from Canon HV-30
    Posted by Harry Katz on May 5, 2009 at 7:06 pm
    Not sure if I took DV or HD footage from my Canon Vixia HV-30… But I keep getting Unable to Initialize Capture Device when I try to capture footage. I’ve changed the settiings in Easy Setup and Audio/Video Settings about a dozen times back and forth and can’t get anywhere. I was able to get to a point where the Capture Now button was available but when I clicked on it the icon just went to the icon of the reel turning for a few seconds, a window seemed to appear for a second then disappeared… I’ve tried the uncontrolled setting but can’t get anywhere. Would appreciate any approaches… Thanks.
    Harry Katz
    hkatz@iijournals.com
    Kent Stipp replied 17 years, 4 months ago 2 Members · 1 Reply
  • Kent Stipp
    May 5, 2009 at 7:57 pm
    have you tried the “HDV” setting on the capture settings. Yes it is generic but if you have tried others try that. OR you can pick a prores setup as well.
    hope it helps
    Kent Stipp
    Life Begins at 155mph
    Ki PRO Lens to Post
    3am Studios llc.
    3amstudios.org
    Sharedsummitsfever.com
