Activity Forums Apple Final Cut Pro Legacy can’t capture audio from mackie 82i mixer/interface in fcp 5
  • can’t capture audio from mackie 82i mixer/interface in fcp 5
    Posted by John O’connor on April 11, 2010 at 5:26 pm
    My mackie 820i mixer interface is showing up in my capture presets in final cut pro 5, but a white window appears and quickly disapears when I attempt to capture live audio from a mic plugged into mixer.
    John O’connor replied 16 years, 4 months ago 2 Members · 2 Replies
  • John Fishback
    April 11, 2010 at 6:21 pm
    I’m assuming this has worked before. Has it? Is any other FW device connected? Although, Macs may have a variety of FW ports, there’s only one FW controller. Often, adding a second FW device can cause both devices to stop working. So, if there’s a second device, remove it and see if that helps. Also, the old standard trash FCP prefs and repair permissions might help.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • John O’connor
    April 12, 2010 at 5:11 pm
    John, thanks for the response. I’m a bit of a newbie with this and am trying FCP for the first time. No other FW devices are connected. On launching FCP I get a message that it can’t locate Apple FireWire NTSC {720 x 480}. I can hit continue and it will launch. FCP is “seeing” my mixer/interface {I can see the 8 channels}, but it won’t capture the audio from the external device.
