Activity Forums Apple Final Cut Pro Legacy Cant Add Effects in Final Cut Pro 5.0.4
  • Cant Add Effects in Final Cut Pro 5.0.4
    Posted by Uriel Reyes on August 11, 2009 at 7:38 pm
    Hey guys and Gals;
    New to FCP, was using it for about 4 months now with no problems when all of a sudden my video transitions and video filters became grayed out under Effects tab. Even the Effects Bar above the Browser window disappeared. I think this became a problem when I changed the name of my scratch disk on my external Hard-drive, Maybe? Any thoughts or Suggestions?
    Gustavo Padron replied 15 years, 6 months ago 3 Members · 3 Replies
  • John Fishback
    August 11, 2009 at 8:11 pm
    Change the name back and see what happens. Also, trash prefs & repair permissions.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Uriel Reyes
    August 12, 2009 at 8:43 pm
    Thanx man;
    Worked like a charm!
  • Gustavo Padron
    March 30, 2011 at 2:09 am
    Hi i got a question, i have Final cut pro 6, i tried to aply a transition or olor correct, but i cannot see the effect on any of the viewer windows, i tried going into system preferences>render control> Checked Filters, i still cannot see any difference.
    I have tried draging to a transition, apllying an effect from the tab and from the menu, could you please help?
