Activity › Forums › Adobe Photoshop › Canopus’s Imaginate 2.0
  • Tim Kurkoski
    June 12, 2006 at 6:16 pm
    The Slideshow Wizard in Photoshop Elements can do a lot of the same things. Imaginate may be able to do some more complex things, though.
    You should be able to build a slideshow using After Effects or Premiere Pro that is comparable or better than anything Imaginate can do. You just have to build it manually.
