Activity Forums Adobe After Effects Canopus Output to NTSC
  • Canopus Output to NTSC
    Posted by Frank Ruggiero on September 10, 2008 at 7:14 pm
    Hi People,
    I have a question for anyone that had the Canopus ADVC 110..
    If you are outputting from Final Cut or viewing out of After Effects, does your sequence/comp need to be set at 720 x 480? Or if you are outputting 720 x 486, does the canpous convert your output to 480?
    In other words, I want to see field issues on output. I do not want the canopus to squeeze the 486 to 480. I want it to crop it and raise it a scanline so that the field order is correct. (Or do I need to do that in After Effects first?)
    Thanks in advance.
    Frank
    Frank Ruggiero replied 17 years, 12 months ago 1 Member · 0 Replies
  • 0 Replies
