Activity › Forums › Apple Final Cut Pro Legacy › Canopus ADVC110 with Final Cut 7
Posted by Peter Chambers on April 25, 2010 at 7:41 pmHi,
I’ve had my Canopus ADVC110 digital converter box for 3 years now and it was working fine up until yesterday. I have it set up from my Mac to output to an external TV monitor. Suddenly, I am getting no output via RCA cables to the TV.
The blue “DIGITAL IN” light is on, but when I push the “INPUT SELECT” button, it doesn’t switch over to “ANALOG IN”.
I’m wondering…is it pooched?
Peter Chambers replied 16 years, 5 months ago 6 Members · 11 Replies -
John Fishback
April 25, 2010 at 9:07 pmI believe that box connects via Firewire. Have you any other FW device connected? If so, try unplugging everything from the FW buss except the 110 and see if that changes anything. Also in FCP, check View Menu > External Video > All Frames is selected.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Tony Brittan
April 25, 2010 at 10:27 pmFrom time to time I have issues with the same box and fcp. For me, it’s been as simple as ADVC needing to be restarted. Just unplug it (I have mine powered by the FireWire so unplug that) let it sit for a few minutes, then plug it back in.
Then you can switch back and forth again and all is right with the world. Well, has been for me so far.
Tony Brittan
Apple Certified Pro – FCP
YouTube.com/tonybvideo
IslandShoreproductions.com -
Mike Sabatini
April 26, 2010 at 12:05 amI’ve had the same experience as Tony. Works every time.
Mike
Peter Chambers
April 26, 2010 at 11:54 amTony — tried to unplug the Canopus and shut the computer down overnight, still no luck.
Peter Chambers
April 26, 2010 at 11:56 amJohn — No other firewire ports are plugged in and I had already tried VIEW > EXTERNAL VIDEO > ALL FRAMES SELECTED. Doesn’t work.
John Fishback
April 26, 2010 at 2:28 pmDo you see the 110 on the FW buss in the System Profiler? Have you tried a different FW cable?
John
Peter Chambers
April 26, 2010 at 2:37 pmWhen I open System Profiler, I can see the ADVC110. The “DIGITAL IN” blue light is on, which means the FW cable must be good…no?
Scott Anderson
April 26, 2010 at 7:07 pmI know this is silly, but the other half of the equation for me is to also try “View>Refresh A/V Devices”. What this does, I believe, is re-poll the Firewire buss for compatible devices.
Often, FCP will not recognize a deck or monitor unless I “View>Refresh A/V Devices”, THEN “View>External Video>All Frames”.
I’m sure you’ve tried it already, but thought I’d throw that in.
Derek Rucas
April 27, 2010 at 12:45 pmDid you try plugging your Canopus into the front firewire ports?
Sometimes those things can be finicky and plugging them into a different port at the opposite end of the computer will do the trick.
