Activity › Forums › Apple Final Cut Pro Legacy › Canopus ADVC110 with Final Cut 7
Peter Chambers replied 16 years, 4 months ago 6 Members · 11 Replies
Peter Chambers
April 28, 2010 at 2:39 pmThanks Derek, it worked. I should have thought to change firewire ports at the beginning. The thing is, when I switched the Canopus from back to front it worked…THEN I plugged the Canopus back into the back firewire and IT WORKED AS WELL!
Those things can be finicky, but thank you so much.
