Activity Forums Adobe After Effects Canopus advc-100
  • Canopus advc-100
    Posted by Joeythedog on August 3, 2005 at 10:11 pm
    Windows xp running After effects 6.5 pro
    What kind of output can I expect from firewire to- canopus to- television?
    Will echo fire assist or make output more informative?
    Will I get real time ram preview to the television as it is playing in After effects? No waiting or other rendering?
    Anything I missed asking?
    Most likely thanks steve
    Steve Roberts replied 21 years, 1 month ago 2 Members · 1 Reply
  • Steve Roberts
    August 3, 2005 at 10:50 pm
    I used Echo Fire, and found it very useful … when it was required. Now, you don’t need EF if you just want FW out. Its scopes were useful, though. Now I use Decklink, and use the scopes in FCP when I need to, but generally, I just knock down the colours when I create them, choosing safe colours right from the start.
    EF uses a different way of previewing, from disk, but if I recall, it’s just as fast as RAM preview. There’s a forum if you need to know more.
    Sorry, I don’t have the Canopus, so I can’t comment. I’ve heard good things, though. 🙂
    HTH,
    Steve
