Activity › Forums › Apple Final Cut Pro Legacy › Canon XLH1 HDV control issues with Final Cut
Christophe De backer replied 9 years, 11 months ago 7 Members · 16 Replies
Shane Ross
October 7, 2016 at 5:30 pmI wonder if it’s the adapter…not passing through SOME information. Have you been able to capture all 3-4 channels via Firewire to firewire?
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
October 7, 2016 at 5:43 pmNo only the first 2 channels.
The weird thing is, the sound plays in the camera during the capture. But once I play the MPEG the sound from Channel 3 end 4 is not their.
Also in CS5 I can’t seem to change the audio setting from 48000Hz to 32000Hz. I think that’s the problem. Just not sure how to fix it.
My FCP 6.0.6 keeps crashing now so I can’t capture anymore via FCPChristophe from Belgium
Shane Ross
October 7, 2016 at 5:54 pmI recalled something about not being able to capture all 4 channels of audio at once via firewire. That you’d have to do a two pass capture…second time only capturing the second “stereo pair.” HOW to do that? I don’t know…that was 10 years ago. I found this forum thread, but it deals with older premiere pro:
So yeah, I think that firewire only does 2 audio channels at the same time, and to get all 4 you need a capture card…or you need to capture it twice, telling the software to get the OTHER two channels the next time.
[Christophe De Backer] ”
Also in CS5 I can’t seem to change the audio setting from 48000Hz to 32000Hz. I think that’s the problem. Just not sure how to fix it. “DV audio is 48Khz…32kHz will make it go off sync. And I don’t know how to capture with Premiere..you’ll have to post in that forum.
Shane
Little Frog Post
October 7, 2016 at 5:59 pmThanks I will ask in that forum and read the post.
Richard Van harderwijk
October 9, 2016 at 2:52 pmHi Christophe
If I remember correct: DV audio is 48kHz with two channels. If you recorded 4 channels it was 32 kHz
October 10, 2016 at 7:48 amThat’s what I thought. And I think that’s the problem. Even if the sound settings of the project are set to 32 kHz in the capture modus I can’t set it to 32 kHz. And the problem now is that my Final Cut doesn’t recognise the camera any more.
Why did I have to go analog in a digital world 🙂
