Activity Forums Canon Cameras Canon XL-H1 w/ a compact flash recorder Sony HVR-MRC1K
  • Canon XL-H1 w/ a compact flash recorder Sony HVR-MRC1K
    Posted by Dave Pascoe on November 23, 2010 at 3:23 pm
    Hi Folks,
    Have a Sony compact flash recorder HVR-MRC1K that I’m trying to use with my Canon XL-H1. The recorder works fine with my Canon XH-A1 and ofcourse other Sony cameras, but for some reason it doesn’t like my Xl-H1.
    The recorder seems to think it’s connected to a computer when the firewire is connected to the camera and is in that mode. It will begin to record (make a new clip #) but will not roll (and no, it’s not in interval recording mode). Tried every menu adjustment I can think of.
    Has anyone seen this problem or have an idea?
    Many thanks,
    Dave
    Roger Van duyn replied 10 years, 5 months ago 6 Members · 13 Replies
  • 13 Replies
  • Brian Louis
    November 23, 2010 at 9:25 pm
    What format are you trying to record? Have you tried it with straight HDV 1080i?
  • Dave Pascoe
    November 24, 2010 at 3:00 am
    Hi Brian, I’ve tried HDV 1080i as well as 30f and 24f – the technical support person I spoke to at Sony said it should be able to read any of these. Strange…
  • Brian Louis
    November 24, 2010 at 11:12 pm
    Have you checked to see if the SDI Out is on in the camera menu?
  • Dave Pascoe
    November 25, 2010 at 1:53 pm
    Yes, I’ve tried it with both the SDI output turned on and off.
    The strange thing is the firewire port works with other firestore drives as well as my edit suite. And the Sony recorder works with other cameras including my Canon XH-A1…it’s got me really confused.
    It seems there’s something in the firewire stream on the XL-H1 that this recorder does not like and I don’t seem to have any menu control over that.
    Dave Pascoe
    http://www.hdsequences.com
    High-Definition Stock Video Sequences
  • Brian Louis
    November 25, 2010 at 11:38 pm
    Have you tried to capture with the H1 as a live cam via firewire to a computer? that will verify there is a signal present.
  • Dave Pascoe
    November 26, 2010 at 12:39 am
    Indeed I have – in fact, I tested it with a Focus Enhancements FS-H200 Pro and it works beautifully…this one has me stumped.
    Thanks for all your ideas though – really appreciate it!
    Dave Pascoe
  • Anthony Negus
    February 8, 2011 at 9:41 am
    Hi Dave,
    Did you ever resolve this problem, because I am going to go exactly the same way with my Canon XLH1S, or to use the Nanoflash.
    Regards,
    Anthony
    primefilmproductionseu.com
  • Dave Pascoe
    February 8, 2011 at 6:09 pm
    Hi Anthony –
    Never did resolve the issue between the Canon XL-H1 and the Sony recorder. I ended up buying a Focus Enhancements FS-H200 (compact flash card recorder) and it works well with my XL-H1 as well as my XH-A1.
    Good luck!
    Dave
    Dave Pascoe
  • Anthony Negus
    February 9, 2011 at 9:45 am
    Thanks for your response Dave, will check out your FS-H200
    Anthony
  • Cesar Sola
    January 25, 2012 at 7:45 am
    hi any one I just thing to buy HVR-MRC1K HD but I will like know is this work with Canon XH-a1s please any can give me information thanks!
    Cesar Sola.
