Activity Forums Apple Final Cut Pro Legacy Canon XHA1s not recognised by FCP 5
  • Canon XHA1s not recognised by FCP 5
    Posted by Barbara Keating on June 17, 2010 at 7:54 pm
    This came into a group I run…..
    “I’m having problems capturing HDV footage from a Canon XHA1s. I get the message:
    “Unable to Initialise Capture Device
    Device is not connected or the capture preset is not setup correctly. You may still log offline clips. ”
    Log & Capture Box says: No Communication.
    BUT
    the Canon XHA1s DOES appear on the Firewire section of hardware connected (about this Mac) and I can capture in iMovie. I’ve checked all the discussion boards but I’m cannot capture footage.
    I’m using Final Cut Pro 5.1.4, Mac OSX 10.6.2: the connection is a 6 pin Firewire.
    Any ideas will be gratefully taken on board!”
    I wondered if it’s just the version of FCP being too old to have those codecs? Help anyone?
    Jerry Hofmann replied 15 years, 11 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    June 18, 2010 at 1:38 pm
    The camera needs to be connected before FCP is started, or you need to refresh A/V devices in FCP. Then the Capture preset set to be HDV or HDV to ProRes, and the device control setting needs to be HDV Basic. Canon uses that protocol. Otherwise you get the error message you’ve posted.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
