Activity Forums Apple Final Cut Pro Legacy Canon XH A1 and Final Cut Pro. Loggin Problems
  • Canon XH A1 and Final Cut Pro. Loggin Problems
    Posted by Uriel Reyes on August 12, 2009 at 8:54 pm
    Hey guys and gals;
    First time trying to log HD video from Canon XH A1. My signal setup when recording on camera was set to: HD – 24F – 1080i/480i. When logging to Final Cut Pro 5.0.4, I changed my Audio/
    Video Settings (Capture Presets) to: DVCPRO HD 24 Copy, due to the fact that I captured on 24 F.
    My problem is: once log and capture is done, instead of video logging in as one entire .mov file, it becomes about 50 movie files which are about 20 seconds long. I can’t work with that!!! Also, while capturing, my capture window is always about 47% behind the actual footage playing on camera. Final cut makes a not of it and tells me to look at my camera for monitoring.
    Are my capture presets wrong? I thought of setting capture presents to HDV, gonna try that now. Any thoughts? Suggestions?
    Andy Mees replied 17 years ago 4 Members · 6 Replies
  • Nate Martin
    August 12, 2009 at 9:12 pm
    24p HDV was not supported until 5.1.2.
  • Uriel Reyes
    August 12, 2009 at 9:19 pm
    then Why was I able to capture?
  • Michael Cummins
    August 13, 2009 at 12:20 am
    I think he means that effectively capturing HDV was not supported until 5.12. In my experience, just because something isn’t officially supported doesn’t mean you can’t partially get away with it.
  • Michael Cummins
  • Andy Mees
    August 13, 2009 at 5:55 am
    Hey, if somethings worth saying its worth saying twice 🙂
  • Andy Mees
