Activity › Forums › Avid Media Composer › Canon XF105 MXF files to AVID Metafuze
Posted by Mikko Leino on May 4, 2011 at 11:09 amHello,
I was wondering that is it possible to bring Canon XF105 MXF files to AVID Metafuze program? I cant really find out strictly specs for supported filetypes…Red…DPX…TIFF so on but how about Canon MFX??
Mikko
Mikko Leino replied 15 years, 4 months ago 2 Members · 2 Replies -
Michael Kammes
May 4, 2011 at 9:49 pmThe Canon XF105 generates a MPEG2 in an MXF wrapper. Media Composer 5.5 has an MXF AMA Plugin which apparently understands this codec.
Camera codec spec:Compression: MPEG-2 Long GOP
Color Space: 4:2:2 (at 50Mbps recording)
File Format: MXF
Recording Modes:
50Mbps (CBR) 4:2:2, 1920×1080, (60i/30p/24p), 1280×720 (60p/30p/24p)
35Mbps (VBR) 4:2:0, 1920×1080 (60i/30p/24p), 1280×720 (60p/30p/24p)
25Mbps (CBR) 4:2:0, 1440×1080 (60i/30p/24p)PDF link (page 3) to Avid AMA MXF Guide: https://avid.custkb.com/avid/app/selfservice/search.jsp?DocId=367189&Hilite=plug-in
Canon XF: MPEG-2 HD 50 and 35 mbits: 1920×1080, 1280 x 720
Canon XF: MPEG-2 HD 25 mbits: 1440 x 1080Thus, it appears Avid supports the codec natively with the MXF AMA plugin…no need for metafuze.
…then again, if you DON’T have 5.5, and you have an older version of Metafuze, I don’t know. Luckily, Metafuze is free! That being said, no where in any literature I’ve found does it list MXF media as being acceptable for INPUT into Metafuze. Listed for input: DPX, R3D, TIF, JPG, AVI and QuickTime files.
One trick COULD be to use a 3rd party plugin (like Calibrated Software) which allows QT to see MXF files. Since QT sees MXF, and Metafuze sees QT…that may work…but that seems kluge at best.
Good Luck!
~Michael
.: michael kammes mpse
.: senior applications editor . post workflow consultant
.: audio specialist . act fcp . acsr
.: michaelkammes.com
.: twitter: @michaelkammes
.: facebook: /mkammesHear me pontificate: Speaking Schedule .
Mikko Leino
May 10, 2011 at 12:31 pmThanks for your response Michael. Well the problem has not been solved and I find it quite odd.
I do have AMA plugin for Canon xf and in media composer everything is working well. But somehow Metafuze does not understand canon’s MXF format. Metafuze should be a converter tool as well so its hard to convert if the converter tool doesn’t support different formats.
So I can import MXF files to composer and change them to mov files and then Metafuze can handle the files. But this shouldn’t be the order. Now I am doing things backwards. Maybe I should use some 3rd party plugin as Michael mentioned but anyway the main thing is that, is it really so that Metafuze doesn’t support MXF files from Canon.
Mikko Leino
