Activity Forums Canon Cameras canon xf100 mxf files show onscreen display i.e. record icon, time/date, zoom info etc….
  • canon xf100 mxf files show onscreen display i.e. record icon, time/date, zoom info etc….
    Posted by William Geigert on December 15, 2011 at 3:16 pm
    I filmed a job and had this information (record light, zoom info, time/date etc…) displayed on screen. At the completion of the job I dumped the contents of the CF card to a HDD. Now, when I view the MXF files in any program all of that info is visible. I NEED IT TO GO AWAY!
    I tried copying the info back to the cards and using a CF reader to then import via Log and Transfer. L&T recognized that there is a card ( I have the appropriate Canon XF utility installed) however it will not populate any of the individual clips.
    I called Canon and the rep pretty much said ‘Yeah, you’re screwed’. I refuse to believe this.
    I am stumped.
    Please help!
    canon xf100, Final Cut Pro 6.0.6,
    Robert John replied 14 years, 8 months ago 2 Members · 1 Reply
  • Robert John
    December 17, 2011 at 7:34 pm
    William on the XF300/305 we can turn on and off character rec. With it turned on, it records all info that you see on the screen to your clip. I know of no way to get this off the video once it has been recorded. I’m assuming the XF100/105 has the similar menu settings. I know this doesn’t answer your problem but thought it might help as far as what caused it.
