Activity Forums Blackmagic Design Canon XA35 – Blackmagic MicroConverter SDI to HDMI – Intensity Shuttle No signal
  • Canon XA35 – Blackmagic MicroConverter SDI to HDMI – Intensity Shuttle No signal
    Posted by Chris Linthacum on September 1, 2016 at 2:40 pm
    We are trying to setup a live monitor for a remote camera location and cannot seem to get a signal. The Canon XA35 has an SDI output, from which we connect the SDI to HDMI converter over 100′ of cable. This should work in theory, yet the intensity shuttle does not recognize any video signal. Additionally, when we connect the HDMI output from the converter directly into a monitor, there is no signal. We have tried every different frame rate and quality available. Any thoughts as to why this isn’t working?
    Chris Linthacum replied 10 years ago 2 Members · 2 Replies
  • Chad Pearson
    September 1, 2016 at 10:29 pm
    What kind of monitor? Is it a computer monitor or a video monitor (TV). Many computer monitors can only handle RGB signals and not the YCbCr format of a video signal (although some can via a menu setting), so they may not be a valid test.
    On the converter, do you see the little white light lit indicating a signal lock?
  • Chris Linthacum
    September 2, 2016 at 1:18 am
    The monitor is an LG 34 inch curved monitor with HDMI input. Neither the monitor nor the Intensity Shuttle recognize a signal when it is connected (via HDMI).
