Activity Forums DSLR Video CANON T3i Recording Stops at 12ish Minutes :(
  • CANON T3i Recording Stops at 12ish Minutes :(
    Posted by Curtis Joel on September 9, 2012 at 12:42 am
    Hey Guys!
    I’m trying to record 20 minutes of continuous video.
    I’m recording at 1920X1080 30FPS with SAN DISK EXTREME PRO 32GB 95MB/S CLASS 10 card.
    The problem is that the camera stops recording after about 12 minutes, every time.
    What do I need to do to record 20 minutes of video without the camera stopping?
    If anyone here has any idea what the issue is, your help is greatly appreciated!
    Thank you in advance!
    Sincerely,
    Curtis
    Shur Harewood replied 13 years, 10 months ago 5 Members · 7 Replies
  • 7 Replies
  • Steve Crow
    September 9, 2012 at 1:46 am
    Hey Curtis, that’s caused by a couple of hard limits built into the camera and there are no effective workarounds – what I do is quickly stop recording and then a second later start another clip but yes I do lose that time inbetween – with the HD DSLRs almost all have some kind of time or file size limit that you will run into – I believe the Panasonic G2 has a hack that you can do it to record 20 minutes
    This is all very well documented online – check it out
    Steve Crow
    Crow Digital Media
    http://www.CrowDigitalMedia.com
  • Phil Balsdon
    September 9, 2012 at 6:15 am
    This is normal on all Canon HDSLRs prior to 5D Mk III (which can do 29.59mins but with broken sequential files).
    One of a number of compromises when using a digital still photo camera to shoot video.
    Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
    https://philming.com.au
    https://www.steadi-onfilms.com.au/
  • Curtis Joel
    September 9, 2012 at 4:46 pm
    I did know these cameras had that limitation but that’s an easy workaround.
    Thank you for your reply Steve, much appreciated! 🙂
  • Curtis Joel
    September 9, 2012 at 4:48 pm
    That’s good to know. The 5D MKIII is now on my wishlist 🙂
    Thank you for your help Phil! 🙂
  • Bill Bruner
    September 10, 2012 at 6:23 am
    The $700 Panasonic GH2 has essentially unlimited recording time outside of the EU. European models are limited to 30 minutes continuous to avoid the camcorder tax. EU models can, however, be hacked to remove this limitation.
    Canons ought to come with a warning label: “shoots for no more than 12 minutes of continuous video – viewfinder and autofocus stop working in video mode”.
    I was actually shocked when I discovered these limitations on my new Canon camera – so I got rid of it and got a GH2, which has none of them.
    Hope this is helpful,
    Bill
    Hybrid Camera Revolution
  • Curtis Joel
    September 10, 2012 at 7:38 pm
    I’ll have to checkout the GH2…that’s good to know. Thank you for the reply Bill!
  • Shur Harewood
    October 22, 2012 at 6:35 am
    Hi Curtis this is a well publicised fact and is also in your instruction manual, even the Canon 1DX or 5D MkIII stops continuous recording at 29.59 mins. This limitation is both a recording and a crucial operational to stop your DSLR being classed as a Camcorder, in Europe this recording length in one take anyl onger would render this in different tax/duty class a camcorder and increase its price.
    Primarily you have DSLR photographic camera that shoot video not the other way round.
    To overcome this limitation you can record via HDMI to an Atmos Ninja or a device that will record hdmi output to a hard disk recorder or capture to a computer.
    Shot, Edit and Enjoy
    Freelance HD and DSLR camera producer and trainer.
    Enjoying the fruits and passion of living life to the full.
    United By Photography
    https://unitedbyphotography.com
