Activity Forums Apple Final Cut Pro Legacy Canon hard drive camera files
  • Canon hard drive camera files
    Posted by Jonny Cates on July 31, 2011 at 10:05 pm
    Hi!….quick question….
    I think I understand the basic hard drive camera workflow now (thanks to Shane Ross) but I’m a little unclear on one simple OS procedure.
    When you first back up your original compressed files from a hard drive cam, do you copy the entire hard drive that mounts up on the desktop; or do you open that drive up – and drag all the folders out and copy them?
    It would seem these folders would need to be put into another newly created folder to keep them all under one roof, and then re-name. Do you then just import that one folder into FCP?
    Just want to make certain if it’s the mounted drive I copy, or is it the folders inside that drive.
    Thanks so much…..
    Jonny Cates
    Jonny Cates replied 15 years, 1 month ago 2 Members · 2 Replies
