Canon EOS C-100: Retain timecode upon transfer
Canon EOS C-100: How do you retain the camera timecode when using the Camera transfer utility? Each clip starts at zero. If the camera data is accessed directly in Premiere, the original timecode is retained but you can’t rename each clip prior to import.
Dan.
