Activity › Forums › Apple Final Cut Pro Legacy › Canon DSLR Proxy Workflow
  • Canon DSLR Proxy Workflow
    Posted by James Taylor on June 9, 2010 at 1:00 pm
    I’m very new to FCP – just installed a couple of days ago. I’m using MB Grinder to make proxy and HQ files. I was able to edit with the proxy files on my 15″ MBP without too much trouble. I then changed my sequence size to full HD and relinked each clip with the full clip and exported the project. My questions: 1) is there a way to relink all the files at one time or do I have to do each one manually? 2) Is this the most efficient proxy workflow? 3) How much of the edit is usually done with the proxy files before you relink the files – just the main edit?
    Thanks for any help with this,
    JT
    James Taylor replied 16 years, 3 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    June 9, 2010 at 6:17 pm
    You can select all files in the sequence at once and reconnect them to the HQ files. Do it as you have been, but select all the clips in the sequence contained in the Timeline window.
    I usually do this reconnection right before I send things to Color for the final corrections.
    You’ll need to change your sequence settings for the HQ files before you reconnect. Usually I duplicate the sequence (keeping the old intact in the event things go wonky…
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • James Taylor
    June 9, 2010 at 11:05 pm
    Thanks Jerry – very much appreciated!
    JT
