Activity › Forums › Apple Final Cut Pro Legacy › Canon DSLR —> Export to YouTube
  • Canon DSLR —> Export to YouTube
    Posted by Jeffrey Cornell on August 13, 2012 at 1:57 am
    I recently shot a comedy show all on Canon DSLR’s which runs about 25 minutes. I’m looking to upload this to the comedy group’s YouTube page. Unfortunately they do not have a Vimeo account so I’d appreciate any help! Some quick info is below to help:
    1920×1080 24p
    Converted to ProRes (LT)
    I tried exporting a QT movie from FCP7 and then bringing that into MPEG Streamclip but the file is still over 10GB. Youtube doesn’t like big files so is there any way to bring down the file size but keep full quality?
    Thank you!
    Jeffrey Cornell replied 14 years, 1 month ago 3 Members · 3 Replies
  • Bouke Vahl
    August 13, 2012 at 10:16 am
    Use the Sony XDcam transfer plugin and export to XDcam.
    Highest quality setting is 50 Mbits / sec, so that should give you a file just under 10 gig.
    And its a fast export, and quality is concidered broadcast quality over here.
    If YouTube does not accept the MXF, you can easilly re-wrap it to QT using the same xdcam transfer tool.
    Or use Compressor to go to anything you like, but the render time will be significant more. (But if your internet connection is slow that will pay of in the end…)
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
  • Ryan Holmes
    August 13, 2012 at 1:29 pm
    You should be able to upload a 10GB file to YouTube (I think the limit is 20GB). Depending on your connection speed, it may take quite awhile, but you can do it.
    If you want to compress it to a smaller overall file size but retain much of the detail, then you’re looking at h.264 as your codec of choice. That can be tucked into either a mov or mp4 for YouTube.
    Vimeo has a good compression settings guide with tutorials. The settings can be easily used for YouTube as well: https://vimeo.com/help/compression
    Ryan Holmes
    http://www.ryanholmes.me
    vimeo.com/ryanholmes
  • Jeffrey Cornell
    August 14, 2012 at 7:56 am
    Great! Thank you for the help! I will try this out!
