Activity › Forums › Avid Media Composer › canon c100 25psf interlaced delivery best option
  • canon c100 25psf interlaced delivery best option
    Posted by Massimo Alberto croce on January 2, 2017 at 9:39 pm
    Hello guys,
    I have a project to set up and i need some advise for the workflow.
    For an interlaced 1080i 50 output, considering most footage coming from a c100 25PF (i think canon mean 25psf)
    is better to change the field motion to progressive and ingest (transcode via ama) as progressive P DNxHD or leave it interlaced?
    thanks in advance
    Massimo Alberto Croce
    Video Editor, Colorist, Pro Tools Editor
    massimoalberto.croce@gmail.com
    Massimo Alberto croce replied 9 years, 8 months ago 3 Members · 3 Replies
  • Bouke Vahl
    January 5, 2017 at 5:32 pm
    It does not matter, you get a motion adapter when you switch to interlaced.
    Edit in interlace if you’re output has to be interlaced. This will render your effects interlaced, and that will look better on an interlace display.
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
  • Job Ter burg
    January 5, 2017 at 6:00 pm
    It’s really simple to create a 1080i50 signal from a 1080p25 sequence. That said, you’ll need to take into consideration whether or not you want your program to stay progressive all the way through. Meaning that there is a motion difference between any DVE moves, title rolls/crawls, wipes, pushes, etc. In 1080p25, these move in 25 steps/second, in 1080i50, these move in 50 steps per second (quite a bit smoother). Some broadcasters require titles be done in 1080i50.
  • Massimo Alberto croce
    January 6, 2017 at 11:46 pm
    Thanks for the info!
