Activity › Forums › Apple Final Cut Pro Legacy › Canon 7d plugin FCP – doesnt see all the clips
  • Canon 7d plugin FCP – doesnt see all the clips
    Posted by Michael Spataro on September 2, 2011 at 6:04 am
    I have searched and have seen the problems with the canon plugin.
    ie. folder format, cutting clips short ….
    I haven’t see this discussed. sorry if there is a thread addressing this.
    i have only used the plugin a few times and it worked great.
    this time i go to transfer and walk away, when i come back its missing files that were there originally cued to transfer.
    then i look though my bin in FCP and it reordered my clip with different names then the source names i left them at.
    Thennnn i go to re-transfer clips and it doesn’t even see them. actually only sees half of the clips in the folder. Whats going on.
    i originally L&T from my internal HD that i keep RAW folders in.
    then i tried my external that i back up files on. neither works. both give me same issue.
    i opened up a new FCP file and same thing.
    i kept the folder format because L&T is able to see half of my files.
    the files aren’t corrupted because i can view all the files in finder and they play fine in QT or i can even drop the original .mov h264 in FCP and edit…
    Help…
    im using a canon 7d 1080p/24f footage. FCP7
    new imac i7 3.4ghz 8gb ram 1gb vram
    Thank you,
    Mike
    Michael Spataro replied 15 years ago 2 Members · 4 Replies
  • Phil Balsdon
    September 2, 2011 at 9:17 am
    Trash your FCP preferences, on the couple of times I’ve had similar problems this fixed it.
    Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
    https://philming.com.au
    https://www.steadi-onfilms.com.au/
  • Michael Spataro
    September 3, 2011 at 3:57 am
    Thanks for the reply.
    how do i trash my preferences ?
  • Michael Spataro
    September 3, 2011 at 4:27 am
    so i trashed the preferences and no luck.
    still doesn’t want to see all of the files in the folder.
  • Michael Spataro
    September 5, 2011 at 3:32 am
    Really need help. nobody has anything?
    i have never used compressor but i guess i will have to here huh.
