Activity › Forums › Canon DSLR Cameras › Canon 6D Accidentally formatted SD card
  • Canon 6D Accidentally formatted SD card
    Posted by Dean Longfield on May 15, 2017 at 11:18 pm
    I accidentally formatted a 64gig Transcend SD card in a Canon 6D.
    I had video footage on at least half the card. The footage is for a client.
    I recreated the problem using another Transcend card and the same Canon 6D.
    (I recorded 5 clips then formatted the card).
    Then I used this Transcend card with the recreated problem and tried to recover the lost footage using the
    Transcend RecoveRx software, the Stellar Phoenix Software and Data Rescue 3 software. None of them work.
    Transcend suggested using their software, and after I told them I did, and it didn’t work they said I could send it in to them but don’t expect much because that’s what they use. Canon has no solution and suggested I contact the card manufacturer, which I had already done.
    What I’m getting is the software identifies video clips. Finds them and tries to recover them. But all I get is a black screen
    that plays 2 or so seconds of audio only and then the audio goes dead as well. I’m currently contacting data recovery services, but don’t know what to expect from them.
    Does anyone have a solution or suggestion? I have read previous threads on this but none of them had a workable solution to the problem. Any suggestions are appreciated. Thanks.
    Dean Longfield replied 9 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
