Canon 5DM3 (and now Canon C100M2) resolution umimpressive (and downright ugly) in Final Cut Pro X
Long time reader of this forum, first time poster. You guys are always soo helpful but I can’t find anything like the problem that I’ve struggled with for a while, so I created an account and joined to ask this question. Something’s gotta give, I’m at a loss.
I’ve been a “professional” videographer for years but my footage never looks as crisp/HD/have the clarity as other videographers with the same equipment. I’m beginning to question my workflow because I recently upgraded my main camera to a C100M2 and the 5D3 is now my backup camera. The footage from the C100M2 is not as crisp and clear as it should be. Something is wrong here.
I have a Canon 5DM3 that I shoot in 1920×1080, 24P, All-I. It looks decent in camera, then I upload from CF card to external hard drive. Then I drag the files from the Finder Folder into the Input Folder in FCP X. Then I start editing… My FCP X settings are to “Create Optimized Media”. Then after the edit, to export I share for Apple devices 1080p. The footage looks OK but never as crisp and HD looking as others who shoot on 5D3 in FCPX. Someone told me to instead of using the share for Apple 1080p setting, export to Master File Default. The video codec for this export is H.264. That doesn’t make it much better.
Some other thoughts… The 5D3 footage in the Finder window looks gross (C100 is better but still lacking). If I open the file directly from import in the Finder window, it’s not sharp at all. In fact, the only place that the footage looks remotely high resolution is in the viewer window of FCP X and it’s usually at 40-60% scaled on “fit”. If I make the view larger than 60%, then it becomes less sharp like in the Finder window. Exported footage looks great on iPhones and iPads because the smaller the scale of the final export, the better. Again, the bigger the scale, the lower res it looks.
Is the problem in the camera? Am I shooting it wrong to begin with or doing something wrong in my workflow once I get it into Final Cut? I’ve found posts from 5-7 years ago that talks about editing in Apple Pro Res instead of H.264 but my understanding is that FCP X now converts for you as “Optimized Media”. Is that so or could the problem be related to the codec I’m using?
I’m attaching screen shots for example.
Thanks again in advance. I know if anyone can help me track down my problem, it’s the readers in this forum.
