Activity Forums VEGAS Pro Canon 5D MKII video in Vegas – a solution
  • Canon 5D MKII video in Vegas – a solution
    Posted by John Matchett on September 16, 2009 at 1:51 pm
    Hi folks,
    I had one of those OMG moments when I was trying to drop some footage from a Canon 5D MkII into a Vegas Pro 9 timeline. The thing wasn’t running right at all – snatching and generally looking like hell.
    I’ve been reading all the back-chat about this on the site – a lot of it seems to involve a lot of trans-coding and buying stuff. However I seem to have stumbled on a simple solution which works well without any problem.
    Normally I set up projects as Progressive 25 fps. This is obviously a problem as the Canon is generating 30 fps. I’ve changed the project properties to 1920×1080 NTSC, (Upper field first – although I think the files off the Canon are Progressive aren’t they?) I pulled in the files, edited them then rendered the whole thing to a new track as AVi using the excellent 1080-60iYUV codec, as recommended by John F. in one of the archived discussions. This does make a pretty big file, but it’s free and it works.
    For final (client) render I’ve used the 720-30P wmv template, using Quality VBR.
    My project was a series of fairly fast engineering machine moves, and they’ve come out sharp and smooth.
    Hope this helps someone. Let me know if I’m missing something obvious or if there’s a better way to set up the project files.
    John Matchett
    John Matchett replied 16 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
