Activity › Forums › Apple Final Cut Pro Legacy › Canon 5d MkII field dominance
Posted by Steve Martin on November 13, 2009 at 7:49 pmHello to all, I was wondering why my imported 1920×1080 .mov clips from the 5DmkII show up in the browser window as having a field dominance of odd. Isn’t this supposed to be progressive material? Not sure how to set my sequence preset now either. Did some testing and output looks good regardless of whether I set it to odd or none. Just want it to be right, any thoughts would be appreciated. Cheers!
Steve Martin replied 16 years, 10 months ago 6 Members · 16 Replies -
Peter Wiggins
November 13, 2009 at 8:31 pmYes it shoots progressive. You really want to convert the files to ProRes or similar first though as you will have to do a lot of rendering otherwise.
Peter
Steve Martin
November 13, 2009 at 8:47 pmYes I converted to ProRes, but it’s the field dominance thing that’s got me scratching my head?
Peter Wiggins
November 13, 2009 at 8:50 pmIf you are editing in 1080p then it should be set to none. For interlaced then it is upper/lower depending on your standard (I’m in the UK so I don’t know about the US)
Peter
Tom Wolsky
November 13, 2009 at 9:26 pmWhat settings are you using in FCP when you bring in this material? How exactly are you getting it into FCP?
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Steve Martin
November 13, 2009 at 10:17 pm -
Tom Wolsky
November 13, 2009 at 10:52 pmWhat are your capture presets? That may effect how the clips are interpreted if they are imported. Also Bridge might be setting field dominance. You can change it to none in the browser, but as the material is progressive it’s not going to do anything to the media because it doesn’t have any fields. As long as the sequence is None it shouldn’t be a problem for anything that’s rendered.
All the best,
Tom
Steve Martin
November 14, 2009 at 1:06 am -
Rafael Amador
November 14, 2009 at 3:46 amBut you haven’t used this preset to capture nothing, don’t you?
This is just a Capture Template with a new name. It have no “frames per seconds” set.
Nothing that you can use.I haven’t found in FC any preset to capture p30.As long as I know there is nothing to capture from the Canon. The signal out of the HDMI is not standard.
You copy H264 from the camera CF to your HD.
Nothing to mess around with field order: Always Progressive.
rafael -
Daniel Dunn
November 14, 2009 at 3:34 pmI transcode it to ProRes LT in MPEG Streamclip, and then either let FCP automatically set my sequence settings when I drop in the first clip, or set the sequence settings yourself. One thing to remember, it shoots a true 30 fps as opposed to 29.97.
It works GREAT as ProRes (any flavor)Daniel
http://www.ddunnproductions.com -
Gary Adcock
November 14, 2009 at 4:42 pm[steve martin] “My sequence settings look like this “
Yo dude..
While the Cannon actually does shoot true P as H.264 video (like RED and Phantom)
Please note in your picture your seq settings clearly states that the format is 1920×1080 (HDTV 1080i 16×9)
While the h.264 file can play as true progressive on a computer the default transport of 1080 video as a broadcast signal is as interlaced or as a progressive segmented frame. see Psf.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, ILhttps://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
