Activity Forums Apple Final Cut Pro canon 5d mark ii native H264 to ProRes in FinaCut X
  • canon 5d mark ii native H264 to ProRes in FinaCut X
    Posted by Javad Ahmadi on August 4, 2012 at 5:19 pm
    Hello everyone;
    Do I have to convert the native H264 to ProRes in Final Cut Pro X before editing? Or it is just fine to start editing. Any advise would be very much appreciated.
    thanks
    Javad Ahmadi
    Alive ProStudios
    Javad Ahmadi replied 14 years, 1 month ago 3 Members · 3 Replies
  • Sandeep Sajeev
    August 4, 2012 at 7:50 pm
    Depending on your workflow, you may want to add Reel and Timecode information to your footage before working with it in FCPX.
    But you don’t need to convert your H264 files to ProRes before editing anymore. Just check the Optimize Imported Media box on import and FCPX will transcode the media to ProRes 422 in the background.
  • Bill Davis
    August 4, 2012 at 11:49 pm
    No. You don’t HAVE to transcode anything.
    The issue is whether your system’s processor and I/O is fast enough to efficiently handle the 5d’s already pretty heavily compressed H-264 data stream in real time.
    Letting FCP-X “optimize media” into ProRes lets the system work more efficiency, since it “expects” that as it’s native codec and won’t have to do any additional transcoding math “on the fly” in order to handle the files internally.
    So you’ll avoid issues like slowdowns and possible dropped frames or sluggish performance when compositing shots or playing back sequences – but X works fine with all types of footage without transcoding IF you have the computing power and system throughput speeds required.
    Simple as that.
    “Before speaking out ask yourself whether your words are true, whether they are respectful and whether they are needed in our civil discussions.”-Justice O’Connor
  • Javad Ahmadi
    August 8, 2012 at 9:55 pm
    Thank you for your feedback!
    Javad Ahmadi
    Alive ProStudios
