Activity Forums VEGAS Pro Canon 1DX 4K footage won’t play in Vegas 18 Pro
  • Canon 1DX 4K footage won’t play in Vegas 18 Pro
    Posted by Justin Ogrosky on March 11, 2023 at 11:24 pm
    Need help with getting my Vegas Pro 18 to recognize the 4K footage I shot on my Canon EOS-1D X Mark II. The footage plays flawlessly in windows media player and Premiere Pro.
    Any suggestions would be greatly appreciated.
    Here is the media info for one of the files:
    General
    Complete name : D:\Vases of Life\4K\BG0I0894.MOV
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt 2015.02 (qt /CAEP)
    File size : 499 MiB
    Duration : 8 s 300 ms
    Overall bit rate mode : Variable
    Overall bit rate : 504 Mb/s
    Encoded date : UTC 2023-04-09 04:56:44
    Tagged date : UTC 2023-04-09 04:56:44
    com.apple.quicktime.make : Canon
    com.apple.quicktime.model : Canon EOS-1D X Mark II
    com.apple.quicktime.rating.user : 0.000
    Video
    Format : JPEG
    Codec ID : jpeg
    Bit rate mode : Variable
    Bit rate : 503 Mb/s
    Width : 4 096 pixels
    Height : 2 160 pixels
    Display aspect ratio : 1.896
    Frame rate mode : Constant
    Frame rate : 23.976 (24000/1001) FPS
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 8 bits
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 2.370
    Stream size : 497 MiB (100%)
    Language : English
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.601
    Gamma : 2.200
    Audio
    Format : PCM
    Format settings : Little / Signed
    Codec ID : sowt
    Bit rate mode : Constant
    Bit rate : 1 536 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 48.0 kHz
    Bit depth : 16 bits
    Stream size : 1.52 MiB (0%)
    Language : English
    Other
    Type : Time code
    Format : QuickTime TC
    Time code of first frame : 23:33:26:04
    Time code of last frame : 23:33:34:10
    Time code, stripped : No
    Language : English
    Brie Clayton replied 3 years, 5 months ago 3 Members · 3 Replies
  • Aivis Zons
    March 12, 2023 at 12:06 am
    Open Vegas Pro, go to Options -> Preferences -> Deprecated Features and tick “Enable the QuickTime plugin”.
    If you don’t see such an option or it doesn’t work, you might have to download/reinstall QuickTime.
  • Justin Ogrosky
    March 13, 2023 at 1:18 am
    Aivis, You’re a LIFESAVER! Worked like a charm. Thank you so much!!!
  • Brie Clayton
    March 14, 2023 at 2:24 pm
    Thanks for letting us know that Aivis has solved your issue, Justin! Aivis has been awarded Creative COW’s Solve award.
