Activity Forums Apple Final Cut Pro Legacy Cannout Output To Proper Aspect Ratio Help!!!!
  • Cannout Output To Proper Aspect Ratio Help!!!!
    Posted by Patrick Morrow on July 10, 2008 at 12:55 am
    I have a sequence that outputs with black bars on the side due to the first clip that changed the standard dv ntsc settings. How can I output it in the proper 4×3 aspect ratio?????
    Thanks!!!
    Tom Wolsky replied 18 years, 2 months ago 2 Members · 1 Reply
  • Tom Wolsky
    July 10, 2008 at 1:03 am
    Make a new sequence in the correct aspect. Copy and paste the contents of the old sequence into the new. Open a clip to see what parameters were changed by the first edit. Use remove attributes to reset those parameters.
    In future if the sequences changes and you start getting pillarboxing or letterboxing you don’t want, stop editing and fix it before continuing.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
